Bike starts & runs but NO LIGHTS! Help
Old Apr 29, 2009 | 11:37 AM
celMNrider's Avatar
Default Bike starts & runs but NO LIGHTS! Help
I just finished painting my bike and was re-installing the front cowl. In the process a buddy of mine decided to help by hooking up the front turn signals and I heard a small, very faint popping sound but thought nothing of it. Once he was finished and once the cowl was reattached I started the bike (perfectly fine) but now the turn signals, headlight, or tailight doesn't work.
I've checked all the fuses for the associated functions and they are good. Funny thing is that the odometer lights work that display the headlights but the turn signals won't flash or work themselves, and neither does the brakelight????
Anyone, please anyone help. In Minnesota there aren't too many good days of riding and Im missing out! I read in a few post that it could possibly be something wrong with the relay? IDK
Old Apr 29, 2009 | 02:06 PM
MartiniRossy's Avatar
Sure the fuses are good? Just because they look good doesn't mean they are. Check them with a meter. Fuse C is all of the lighting except the headlight and fuse A is for the headlight. Other than that you have a ground(s) disconnected or poorly connected. Check the connector that goes to the ignition also.
Old Apr 30, 2009 | 12:21 PM
celMNrider's Avatar
Ill check that later this afternoon. Were you just referring to a regular voltage meter?
Old Apr 30, 2009 | 12:53 PM
gotcbr's Avatar
I agree...check fuses. Also, did you use connectors or just use electrical tape on those connections? Could be that a wire still isn't covered & is touching bare metal somewhere.
Old May 1, 2009 | 12:03 AM
limpy88's Avatar
if the wiring and fuses are good check the highlow switch. mine broke inside and i had no lights. had to replace it
Old May 5, 2009 | 09:31 AM
celMNrider's Avatar
Thumbs up
Thanks. The problem was two-fold, the connectors werent really connected since I was just using electrical tape, and the connection behind the front cowl was partially lose and wasn't connected all the way. I have since made sure all the wires have the right connector. Thanks for your help everyone. She's up and running
wakethis2006
Apr 23, 2009 11:04 PM
viva_brasil
Apr 3, 2008 11:16 PM
Jsalty
Aug 12, 2007 12:49 AM
dragonium25
Sep 30, 2006 10:51 PM
dragonium25
Sep 30, 2006 10:50 PM
