Bike hesitates when i turn blinkers on, hmmm.
Old Jun 22, 2006 | 01:29 AM
jeffrimerman's Avatar
Default Bike hesitates when i turn blinkers on, hmmm.
When i am making a left or right turn and I hit the blinker switch i feel and hear the engine miss fire then it is ok after that split second. What could be causing it? I also think my fan is not working anymore, but that could be a separate issue. I don't think that is normal. Could there be some short and if there is shouldn't cause it to keep missing when the blinkers are on. It only duz it for a split second.
Old Jun 22, 2006 | 12:27 PM
Angryviking's Avatar
Default RE: Bike hesitates when i turn blinkers on, hmmm.
Checked your fuses?
Old Jun 27, 2006 | 10:45 PM
Yeha i checked and that fixed the fan problem, but i don't think fuses should cause the hesitation problem. Its almost as if there is a major drawl on power for a second and this is enuff to zap the power to the spark plugs. Could it be the coil? Duz it have a coil?
Old Jul 7, 2006 | 03:38 AM
Shaken's Avatar
ya my bike does that when the fan turns on but cant figure out why. it runs like a top until the fan turns on then it stars to bog somtimes dies and if you give it gas it hesitates for a second and off we go. i am taking it to honda next week see if they can sort it out. i will let you know we might have the same problem.
Old Jul 7, 2006 | 03:48 AM
Ok, kewl yeah that would be great if u let me know wut ur problem wuz. Mine is fine with the fan. It is only when i hit the blinkers it seems to die for a second then goes just fine after. I don't think it is the fuses since they are all fine and there is 4 different coils so not that either. Why would the power to the entire ignition system be disturbed by the blinker drawing power? That is the question. Wonder if there is some sort of power relay switch and some sort of capacitor that isn't functioning correctly?
HellrazerinDC
Feb 22, 2012 02:49 PM
Leugs31
Mar 15, 2011 02:34 AM
stang68
Apr 30, 2009 10:59 AM
