small prob with blinkers/Turn Single
Old Apr 28, 2009 | 10:53 PM
stang68's Avatar
Unhappy small prob with blinkers/Turn Single
hey every one im haveing a small prob my blinkers some times thay work fine but others it dosint work at all and others it gos in but dosint blink it jsut stays on .. i know it has to do with the electrical becose if thay dont work or it stays on with out blinking i turn it off rev the motor and try agean and it work s fine any ideas will help please let me know
Old Apr 28, 2009 | 11:20 PM
CaliKush's Avatar
im guessin loose wiring? unless the relay is goin bad?
Old Apr 29, 2009 | 10:16 PM
nodaker's Avatar
Had the same problem last year. Blinkers did not work until I hit a bump. The relay was bad. Im willing to bet you have some bad contacts. I think the relays are pretty negotiable.
Old Apr 30, 2009 | 10:59 AM
Golferbest's Avatar
I'd have to agree on the relay. But if u have the time, get a wire tester( or voltmeter) and check out the wiring. You might have a loose ground, or a power wire that is grounding out due to being exposed and touching metal. It takes awhile but not a hard task..
John Brown
Nov 27, 2013 05:47 PM
ohio nitro
Apr 21, 2013 07:25 PM
shortfuse
Mar 30, 2009 12:07 AM
oasysco
Mar 28, 2009 10:32 PM
CBRider206
Apr 24, 2006 09:08 PM
