954 turn signal prob... need help
Old Dec 13, 2008 | 01:25 AM
shortfuse's Avatar
Default 954 turn signal prob... need help
ok i have a 03 954. i just put a new set of blinkers, mainly because it didnt have any. I soldered them in and made it really clean. but now my blinkers stay on constant, both sides and the rear does the same thing. in there a possibility that the relay is trashed? Im lost i took off the whole front fairing and went through the harness lookin for a short but i cant find anything. and the rear signals stay on all the time too. thats why i think it is the relay
Old Dec 13, 2008 | 09:19 AM
nikos's Avatar
Default RE: 954 turn signal prob... need help
The fronts are used as running lights as well as turn signals, so there should be three wires running to each front (running lamp +, turn signal +, and ground). You may have used the wrong wires... I would check the service manual to tell you which colors do what, but I'm feeling too lazy...
Old Dec 26, 2008 | 09:54 AM
CBR954RaceReady's Avatar
There are only 2 wires. but you might wanna try to use stock bulb. that will probably make diffrence.
Old Mar 30, 2009 | 12:07 AM
six100f4i's Avatar
had the same problem with my f4i, you used LED signals didnt you? mine work great with only two wires connected, the just blink a little fast because i didnt use a resistor. but if you connect all 3 wires to use them as running light also then you end up with the problem you are having. i just left mine with 2 wires connected, dont really need them as running lights anyway.
ohio nitro
Apr 21, 2013 07:25 PM
MrBlaze
Aug 17, 2009 02:07 AM
stang68
Apr 30, 2009 10:59 AM
Cun0144
Sep 23, 2008 10:04 AM
CBRider206
Apr 24, 2006 09:08 PM
