Bar end constant problem
Old Dec 5, 2008 | 11:15 AM
scastillo13's Avatar
Default Bar end constant problem
I've notice that my right bar end keeps coming loose, and when I tighten it up it only goes so far before spining loose u can say. After tighting up it might last a month before its loose and bout to fall off. Is the problem the screw or the frame where it goes into? Would a lil bit of cheap glue holdit in place, or that white tape thats used in pipe fittings? Anyone had this problem before, any solutions??
Old Dec 5, 2008 | 11:17 AM
Nauree's Avatar
Default RE: Bar end constant problem
Locktight
Old Dec 5, 2008 | 11:19 AM
I can only tighten it up so much, then it just spins loose again . . .
Old Dec 5, 2008 | 08:19 PM
bigboi18184's Avatar
Loctite Thread Sealant 542 Fine Threads - 50 ml Tube (442-21453)
$36.64
Loctite Thread Sealant 564 - 50 ml Tube (442-28754)
$20.67
Buy
Loctite 561 PST Thread Sealant Stick - 19 gram White (3UU53)
$10.71
Buy
better than that white thraed tape, it will hopefully keep the threads from backing off and loosening up.
Old Dec 5, 2008 | 09:42 PM
Nauree's Avatar
I miss spelled it
blackout357
Mar 23, 2011 07:33 PM
jerryh1980
Jul 10, 2010 12:26 AM
CBR.600.F4
May 2, 2010 10:07 PM
Baooo
Nov 10, 2009 07:22 PM
jdschmidt
May 27, 2008 02:46 PM
