Back brake problem??????
Old May 24, 2007 | 02:15 PM
99 CBR F4 Man's Avatar
Default Back brake problem??????
I can get my back break to lock up my rear tire. i have good pads my rotor looks good also. When i press the break it slows the bike down it just doest lock it up. Im not exactly sure if its suppose to lock it up or not. please help me.. everyone telles me it should lock up the tire and by the way my brake fluid level is where its suppose to be. HELP????
Old May 24, 2007 | 03:49 PM
78sharpshooter's Avatar
Default RE: Back brake problem??????
You might want to bleed the system. If there is air in there you wont get as much braking power. Did the fluid ever run very low at one point?
Old May 24, 2007 | 04:59 PM
Beowolf150's Avatar
Thats kinda a good thing. You don't want to lock up the rear tire or thr front for that matter. Your brakes are the best when they are almost at the point of locking up but don't. If you really want to lock up the rear then you are going to fish tail, and your going to laid it down.
Read this it will tell you all you want to know about braking, and lots more
http://rapidshare.com/files/30464376...Techniques.pdf
Old May 25, 2007 | 02:11 AM
MikeMirage's Avatar
If you want to lock up your back wheel just slam on the back brake as hard as you can and it will lock up. Trust me! I don't recommend trying it though and if you do remember not to let off the back brake till you come to a complete stop (hopefully you are still on the bike at this point0.
Old May 25, 2007 | 02:25 PM
man i can stand on my break and jump up and down on it and i still cant get it to lock up. i have tried bleeding it several times. i dont know whats wrong
Old May 26, 2007 | 11:40 PM
cbrwrx's Avatar
bad master cylinder?
Old May 27, 2007 | 03:42 AM
Beowolf150's Avatar
Dude it's is not ment to lock up...IT"S A GOOD THING
Old May 29, 2007 | 12:11 AM
ajlong's Avatar
How does the pedel feel? is it soft or firm? If it's firm, your pads could be going, if it's soft, and there is no visible leak, your master cylinders needs to be looked at. Just my $0.02
edubF3
Jan 6, 2011 07:02 AM
kaska
Mar 29, 2009 01:46 PM
bicklebok
Oct 14, 2008 11:54 PM
pfsnsd
Aug 28, 2007 07:55 PM
MarkR
Sep 9, 2006 04:44 PM
