#1 Cylinder not firing
Old Oct 10, 2007 | 11:17 AM
jpw's Avatar
jpw
Default #1 Cylinder not firing
Any ideas for troubleshooting? #1 cylinder is not getting hot. All spark plugs are brand new NGK's.
Old Oct 10, 2007 | 11:51 AM
Sand.Man's Avatar
Default RE: #1 Cylinder not firing
Did the problem start when you put in the new plugs? check the plug and see if it's faulty, sometimes they just dont work.
Aside from that, the #1 carb could be blocked.
Old Oct 10, 2007 | 11:58 AM
jpw's Avatar
jpw
Good idea...i did not try a different plug to see if another one worked. Fortunately it's the carb on the outside opposite the dial, so i can pop it off to make sure there is not trash in the fuel entry port.
robuk
Nov 27, 2012 06:15 PM
derekvercher
Mar 24, 2012 01:03 PM
SFK94F2
Mar 6, 2009 10:10 PM
two240s
Oct 18, 2007 06:30 PM
matt_m427
Oct 29, 2006 05:41 PM
