01-04 plastics?
Old 07-29-2012, 02:31 PM
JishMan's Avatar
New Member
Default 01-04 plastics?
will o1-04 CBR RR plastics fit on a 2000 F4?? i know the front head light assembly and the seat set up are different but will they bolt on? also will the seat off the 01-04 snap right in? and will the head lights all bolt right up as well??
Old 07-29-2012, 03:00 PM
Turbulenz's Avatar
Official Welcome Crew
they bolt right on! After you get the headlights, fairing stay, stay to frame bracket, find a way to mount your F4 gauges (or swap in F4i gauges), ram air covers (I think you have to modify them).. its not a difficult swap, but you have to read up on it well.. do a search on here.. there is also a sticky on making the dual headlights work.
the side fairings are the same and your F4 tank will be fine.
good luck
Old 07-29-2012, 06:37 PM
cuetip's Avatar
yep its very easy, and if you want the split seat, thats an easy swap to
Old 07-29-2012, 08:30 PM
Shueisha's Avatar
For the split seat, do you need to have the F4i sub frame or can you use the F4's ?
Old 07-29-2012, 08:31 PM
Turbulenz's Avatar
01-03 f4i split seat subfame, it's black.
Old 07-29-2012, 08:36 PM
gotcbr's Avatar
For a standard split-seat conversion from banana seat, yes you need the '01-03 split-seat subframe. You also need the split-seat battery tray, seats, tail plastic, tail light, misc hardware. Please see my split-seat tutorial for more info. You can link to it from my sig-line.
Old 07-29-2012, 08:40 PM
gotcbr's Avatar
Are you asking if the F4i or 600RR plastics fit the F4?
F4 to F4i conversions are easily done.
Note: '01-03 F4i have split-seat tails. '04-06 F4i's have banana seat tails. '01-06 all have the same front fairing w/ dual light setup.
If you're looking to do the split-seat conversion ('01-03 F4i tail), as I said in the post above, please see my tutorial.
Old 07-30-2012, 05:33 AM
Turbulenz's Avatar
Doh! I just assumed he asked f4i...
Old 08-02-2012, 07:17 PM
JishMan's Avatar
New Member
i found a set of 01-04 600RR racing plastics for a great deal, i need to plastics for the bike and trying to get get a set cheap. i dont think im going to change everything just so they fit, i guess ill just keep waiting till i can find a set that wont cost me an arm and a leg. thanks for all the info though...
cumminsboy3
06-11-2009 09:19 PM
chiefF3
05-01-2009 11:04 AM
12 O Clock
03-08-2007 12:58 PM
DevenJames2005
01-08-2007 09:10 PM
Quick Reply: 01-04 plastics?
