01-04 plastics?
will o1-04 CBR RR plastics fit on a 2000 F4?? i know the front head light assembly and the seat set up are different but will they bolt on? also will the seat off the 01-04 snap right in? and will the head lights all bolt right up as well??
they bolt right on! After you get the headlights, fairing stay, stay to frame bracket, find a way to mount your F4 gauges (or swap in F4i gauges), ram air covers (I think you have to modify them).. its not a difficult swap, but you have to read up on it well.. do a search on here.. there is also a sticky on making the dual headlights work.
the side fairings are the same and your F4 tank will be fine. good luck |
yep its very easy, and if you want the split seat, thats an easy swap to
For the split seat, do you need to have the F4i sub frame or can you use the F4's ?
01-03 f4i split seat subfame, it's black.
Originally Posted by Shueisha
(Post 1180959)
Originally Posted by JishMan
(Post 1180875)
F4 to F4i conversions are easily done. Note: '01-03 F4i have split-seat tails. '04-06 F4i's have banana seat tails. '01-06 all have the same front fairing w/ dual light setup. If you're looking to do the split-seat conversion ('01-03 F4i tail), as I said in the post above, please see my tutorial. |
Doh! I just assumed he asked f4i...
i found a set of 01-04 600RR racing plastics for a great deal, i need to plastics for the bike and trying to get get a set cheap. i dont think im going to change everything just so they fit, i guess ill just keep waiting till i can find a set that wont cost me an arm and a leg. thanks for all the info though...
