wiring help
Old Mar 18, 2010 | 09:44 PM
bigwill74's Avatar
Default wiring help
Hello to all, I just bought a 98 CBR 600 that already had the aftermarket integrated tail light. The problem is that in order to pass the state safety inspection I had to replace it with DOT approved lights.No problem I thought until I looked at the mess back there, I have tried everything to get DOT's to work properly and now I have no brake lights. I think I am just too stupid to figure out the proper wiring. Any help would be appreciated. Thanks
Old Mar 18, 2010 | 10:42 PM
Craig84's Avatar
well i just put an integrated tail light in on my 96 f3, the green wires are the ground and the blue is for the right turn signal positive, and the orange or yellow i forget is the left turn signal. im sure someone will show you a schematic, unfortunately i dont have one, just the knowledge of what i just did, if it helps..
Old Mar 19, 2010 | 04:15 PM
bigwill74's Avatar
Default Battery is now dead
Well I messed around with the wiring on the bike, but now the battery is dead. I tried to charge it but it died after I let the bike run for about an hour. Just wanted to know if the problem could be deeper than just the battery. Rectifier, stator, demons perhaps..any help from you guys would help, local shop says they will look at it and fix it for $500..I would prefer to do it myself. Thanks
Old Mar 19, 2010 | 05:38 PM
ajzcamaro's Avatar
I just swapped from my 95 tail with integrated taillight to a 98 tail with stock lighting. Let me know exactly what you need to know and I'll see what I can do. Pics would probably help too. Did you just allow the bike to idle for an hour, or did you actually ride it? The bike doesn't start to charge until like after 4,000 rpm.
Old Mar 19, 2010 | 06:01 PM
Kuroshio's Avatar
R/R and stator shouldn't be affecting the lights like that. Maybe popping fuses constantly. But not lights one day / no lights the next and no other symptoms. Battery died cause of what ajzcamaro said: bike doesn't charge the battery while idling
Gimme a sec and I'll snap a pic of my brake light's wiring before I take it out.
Old Mar 19, 2010 | 06:34 PM
Kuroshio's Avatar
This it the connection from the wire harness to the brake light. Colors are Brown - Brown, Green - Green, Green / Yellow - Green / Yellow
That's where they split to the 2 lights in the brake.
Going by the wire diagram in my Haynes manual it looks like Green goes to ground, Brown goes to the gauges (prolly for power) and Green / Yellow goes to the brake switch
Old Mar 20, 2010 | 09:12 AM
marc0011's Avatar
The brown is the constant (tail light) for the brake lamp sockets. The should only be two wires for the rear signals sockets since there is no marker lights in the rear.
Old Mar 5, 2013 | 02:56 PM
jasonlee's Avatar
Hey guy's,
I just switched mine to an integrated tail light and connected it all as above photo's. yet the brake light will not work.
Any ideas why????
p.s. there should be no bulbs in any of the two sockets should there??? as one is for factory led fitting, the other is blank.
leonf4i
Oct 10, 2009 07:24 PM
AALBA2
Mar 31, 2008 08:55 AM
93_ka24det
Mar 25, 2007 06:38 AM
bignibb
Feb 13, 2007 10:22 PM
mastice
Nov 26, 2005 04:37 AM
