What is involved in replacing a shock?
Old 02-16-2006, 02:43 PM
jaboyak's Avatar
Default What is involved in replacing a shock?
I'm curious because my stock shock is shot. How and where would I lift up the middle of the bike to relieve pressure? Any help would be awesome. Thanks guys.
John
Old 02-16-2006, 07:28 PM
chainstretcher's Avatar
Admin Emeritus & MVN
Default RE: What is involved in replacing a shock?
If you have a stable overhead rail then use nylon straps and lift from the frame behind the seat.
Old 02-17-2006, 12:10 AM
Well is it the front or rear? If its the rear take off the seat and lift it with a cherry picker or somthing if its the front take of the fairings and do it only a few bolts holding it on but you will have to take off the clip on as well
Old 02-17-2006, 01:26 AM
the best way i found is to put jack stands on the rear sets not on the pegs thats how i got my swing arm off and shock but be careful when u do that because the bike can fall over it might be better to loosen the bolts befour u put it on jack stands hope this helps you
pjtime
05-04-2010 02:15 PM
12Pack
04-01-2009 12:42 PM
cjr5137
02-17-2008 06:26 PM
PegCBRF4i
12-05-2005 11:16 AM
Quick Reply: What is involved in replacing a shock?
