Weird electrical problem
Old Nov 30, 2012 | 02:10 PM
sifiwiz's Avatar
Default Weird electrical problem
Hi guys, last night as I was going out to take the bike for a ride, I noticed some weird electrical problems. The entire gauge cluster won't come on, nor will the oil indicator, neutral light, side stand light, or brake lights. But, the headlights come on and the bike runs fine. Any ideas??? I thought about fuses but I have no idea where the other fuses are.
Old Nov 30, 2012 | 07:20 PM
MadHattr059's Avatar
There is a side panel, on the right. Just below the bars, in the fairing.
A single screw holds it in place.
Don't assume, looking at a fuse, that it is good. Always either test them
or replace with a known good or new one. Don't assume a new one is good.
Try several, that will lower the odds of a factory-failure, clouding the issue.
Also, check the two big harness connectors (and the myriad of small ones),
that connect under the guages, at the mainstay. A loose connection will
often cause similar problems.
Good luck, Ern
Old Nov 30, 2012 | 10:44 PM
sifiwiz's Avatar
There is no fuse box where its supposed to be....... wtf. I looked more closely and it looks like the previous owner wired aftermarket turn signals and led rear lights. He bypassed alot of the wiring and it looks like a complete mess. I think i might just rewire the entire bike to simplify it all. Maybe run everything in the rear independently off of the front brake/rear brake and a master switch. I'm trying to decipher this wiring diagram, it looks like everything(turn signal, brakes, speed sensor) are all connected to each other. Its gonna be a pain in the a$$ to figure out whats wrong.
Old Nov 30, 2012 | 10:45 PM
sifiwiz's Avatar
Btw thank you for a quick reply, I also noticed that when I tried riding it it seems to sputter/cut off around half throttle, like its starved for fuel. Air solenoid valve?????
Old Dec 1, 2012 | 10:16 AM
Another option to think about would be to replace the wiring harness with a used one from ebay. Having one that's not hacked up might prove to be more reliable in the long run.
Old Dec 4, 2012 | 09:13 PM
The_best's Avatar
Bump, New to the site. Im having the same problem on my 96 f3 600. Fuses good. Checked the 2 plugs into the cluster,, When i try to choke to high the bike dies, but itll run on low, i know your not suppose to run it far like that.
Old Dec 7, 2012 | 09:25 AM
The_best's Avatar
Main fuse is good. Help anybody?? And i'm getting power to the cluster but no nothing.
7starF2
Apr 10, 2013 04:53 PM
Gnarly 928
Sep 18, 2012 04:55 PM
Broheim
Nov 1, 2008 03:11 PM
F4iMane
Aug 17, 2008 10:10 PM
TennesseeCBRF2
Oct 19, 2006 10:23 PM
