Water Pump problem
Old Aug 14, 2013 | 09:52 AM
aan310's Avatar
Registered Users
Default Water Pump problem
So I went to flush the cooling system - I pulled the hose running from the radiator to the pump to start draining.
When I start the bike there is no movement of fluid from the reservoir and no suction coming in or out of the hoses.
So I need a new water pump? or?
Thanks!
Old Aug 15, 2013 | 03:57 AM
jackojeff's Avatar
the 'reservoir' isnt a reservoir its an overflow tank
empty it then fill your radiator up until it starts to fill the reservoir when it is half way between low and high your good to go.
fill radiator
run bike for 10-15 minutes
refill radiator as needed
if at the end the radiator is full and no air in the system and the overfill still hasn't any water then just manually fill it.
ucyifly
Mar 31, 2013 09:50 PM
davydave
Jul 25, 2009 10:23 AM
domon
Jun 2, 2009 03:16 PM
domon
May 31, 2009 11:21 AM
sandtown929
Apr 16, 2008 10:10 AM
