VRR 3rd party or oem?
Old May 8, 2016 | 05:56 AM
MystaMagoo's Avatar
Default VRR 3rd party or oem?
98 600F
Battery starting/charging problem?
After a decent ride out,stopped and battery seems flat bike won't start,go for just a couple of mins,stop and bike starts ok.
Starts after being sat in garage all night..............
Going to replace the regulator/rectifier
Checking ebay for replacement,cheap Chinese to OEM quite a difference in price as you would expect.
So 3rd party or oem?
So just took it out for a shortish run,fired up ok and off we went.
1hr later and thankfully just as I approach my garage the bike just cuts out.
Life is in the battery but barely turns over if at all,lights work and seem quite bright,dash lights are also nice n bright.
Does it sound like the VRR?
Old May 8, 2016 | 10:24 PM
coalminer frank's Avatar
You need a Clymer, Haynes,or Honda shop manual that tells you how to check the electrical system and components, before you start wasting money replacing parts that dont need replaced. I wouldnt waste money on a cheap chinese one, a brand new OEM replacement would probably last a while or some people get a used GSXR or R1 from ebay, way cheaper and more durable. I cant remember which years to use but its here somewhere on this site.
Old May 10, 2016 | 03:20 AM
MystaMagoo's Avatar
Friend had a spare but now there's no life in the system at all.
Even when I tried a jump from my car
Will take it to my mechanic and let him sort it.
Friend had very similar problem which is why they have spare VRR,turned out it was their stator.
Old May 18, 2016 | 01:02 PM
MystaMagoo's Avatar
Turned out to be a fuse of all things.
The main one atop the solenoid.
Old Apr 8, 2018 | 04:27 AM
MystaMagoo's Avatar
New problem,not sure if it's related to this old one??????
It's kinda weird......
This is when riding
Battery goes flat when using lights,there is a charge being sent to it but it goes flat.
Turn the lights off and battery gets charged.
When garaged
If light switch is on battery goes flat.
Light switch in off position charge stays in the battery.
Any ideas or where to check etc etc?
Old Apr 8, 2018 | 10:30 AM
wes 17's Avatar
Unplug R/R. Three yellows ? Check for continuity between them. There should be none.
Old Apr 9, 2018 | 08:03 AM
BwanaTumbo's Avatar
Reg Rec is fried by the sound of it......
Old Apr 10, 2018 | 07:37 AM
TimBucTwo's Avatar
Originally Posted by MystaMagoo
When garaged
Sounds like a short somewhere. I'd disconnect the battery and see if there is continuity to ground from the + headlight wire. Try with the switch open then closed to see what side of the switch its on. If it were the R/R it would discharge whether the switch were open or closed.
Old Apr 15, 2018 | 06:04 AM
MystaMagoo's Avatar
Mechanic did a small test.
Renewed all connections going to R/R,tested with voltmeter ( male connections that go into R/R ) and all seemed ok.
Lights off,engine running = decent charge going to battery.
Lights on,engine running = no charge going to battery.
He reckons R/R is knackered.
M&P have R/R on sale,£20 down from £60 so will try that 1st but I think it's a short somewhere but I'm no mechanic......
Old Apr 20, 2018 | 01:23 PM
MystaMagoo's Avatar
My mechanic,as usual,is spot on.
Problem seems to be fixed with the new R/R.
Don't know why I thought otherwise lol
andymp3
Oct 14, 2009 09:51 PM
demonchild
Jan 22, 2007 01:59 AM
telgren
Jan 21, 2007 04:25 AM
Oh_Gee!
Jul 2, 2006 02:18 AM
