Vacuum line
could use some help finding out vacuum lines. On the bottome of the carb boots on the cylinder head there is a vacuum nipple coming off each carb port. 2 of them have a rubber block off and the other 2 are open like a hose goes on there. i can take pictures if anyone needs me too. its a 1991 Honda cbr 600 f2 BUT i just put a 1995 honda cbr 600 f3 motor in with harness and all.
as duck said those are the taps for carb syncing. i know at least cylinders 2-4 should have the nipples and rubber pieces, not sure if #1 should cause on mine theres just a screw, but the ones without the nipples and rubber pieces, just get a short screw that will fit in there and use a small oring and a washer to make sure its sealed.
