Turn Signal Problems
Old Apr 20, 2006 | 09:40 AM
czycoot1318's Avatar
Default Turn Signal Problems
I have these kind of flush mount turn signals, can anyone tell me what kind of bulb goes with this? I have looked all over for the amber color bulb that I need, and can't find it. There is no part number on the actual bulb, so if anyone has any knowledge of what the number is, I would appreciate it. Also, I tried some clear bulbs, but they weren't right, I blew a fuse on the way in to work. I had no tail light, turn signals, dash lights, speedometer, tachometer, temp gauge. The bike was bogging down real bad, and it has never done this before. Could this be a problem from the fuse blowing? I replaced the fuse, and disconnected the front signals that have the wrong bulbs in them, and everything appears to be working fine. Now I am at work and can't take it for a test ride, so I am hoping it was bogging down because of an electrical problem. Any help would be appreciated.
Old Apr 20, 2006 | 08:39 PM
Default RE: Turn Signal Problems
anyone have any ideas?
Old Apr 20, 2006 | 10:49 PM
cbrclan's Avatar
My best suggestion is, take the bulb out and take it to a local auto shop to see if they have anything. Many times they do.
Here is what I found about the bulb:
Wiring Two Wire, 12 Volt Systems
Bulb Amber bulbs 23 watts single filament
Manufacturer: BikeMaster
Item #: F-14164
I have the same exact flush mount on my 95 f3, however I have not encounter that problem. Maybe the reason why your experiencing the breaking fuse is the voltage for the bulb might be different?
Old Apr 21, 2006 | 01:30 AM
I put the wrong size bulbs in (Watts). That's why I blew the fuse. I disconnected the signals and put in a new fuse, and the bike runs great. Must have had something to do with the electrical. Thanks for the help, I'll see if I can find that bulb online.
Old Apr 21, 2006 | 01:33 PM
cbrclan's Avatar
Not a problem.. Happy Riding!
flyinpoon
Jan 25, 2012 04:52 PM
illy600
Apr 30, 2010 06:38 PM
diguise88
Apr 6, 2010 03:14 PM
oldwhite600
Aug 19, 2009 09:41 AM
RockStaRR
Jun 21, 2007 04:51 PM
