tuning/tyres
Old Mar 26, 2012 | 08:58 AM
pete5956's Avatar
New Member
Default tuning/tyres
Hi, just a couple of questions for you guys.
It time to change the rear tyre on my 95 f3, I have a 160/60/17 on the rear which I believe is standard, but the front is a 120/70/17! I know the standard front is 120/60/17, am I gaining anything by the higher profile on the front, or should I put the correct tyre on when I change the rear?
Also I have a k&n filter fitted, but have heard a few times that it will make it worse, is this true or should I fit a standard filter? I have ss nexus exhaust with down pipe as well!
Thanks Pete
Old Mar 26, 2012 | 11:19 AM
Hyperblau's Avatar
The general consensus seems to be that either a K&N or a slip on is okay, but both together should probably prompt a re-jet. I'm sure one of the gurus can give you a more detailed answer.
caprinut
F3 Wanted
Oct 5, 2011 04:01 PM
madmike01uk
Sep 11, 2007 08:48 AM
weekendrider
Jul 7, 2007 03:28 AM
nessy38
Apr 29, 2007 02:06 AM
f4iguy8804
Apr 17, 2007 09:57 PM
