trouble starting 1995 F3 (spark plugs??)
#21
hey, you say it takes you 5 mins to change them... please tell me what tool you use to do that cause I was having a hard time getting to those middle to with that air box right there... I had taken it off to get to them originally but still couldnt really get the angle in there..
they make a special toolkit for the f3 which you can get on ebay (got mine for 12.00) which has tools that allow you to do the job in a matter of minutes, however Idodirt's method works just fine, and the only difference in his tools and the toolkit, is the socket part which grabs the sparkplug bends and allows it to curve out (so it doesnt bump the airbox/frame when gettting it out). it also has a rubber gasket which holds the plug and allows you to pull it out without using your fingers.
#22
#23
hope you get her running again!
#24
you can jump it from a car, however, make sure the car is not running.
#25
I found a magnetic plug socket does the trick (same methodology otherwise) - although I did end up with a serious case of "Mechanics Knuckles" and the neighbours may not have appreciated some of the language coming from my mouth - it *is* possible to get to all 4 plugs without removing anything other than the side fairings.
#26
replaced the fuel pump relay and fuel pump... got a trickle charger and charged her all up... still wont start. so i guess im back to the spark plugs. can anyone find me a link to the tools I would need to change the plugs out easily as mentioned in some of these posts? thanks for all the help!
WildWill
03-21-2009 10:10 AM
Addammer
03-14-2007 07:59 PM
