Transmission Noise?
Old May 30, 2006 | 01:20 AM
crookedeyemotocross's Avatar
Default Transmission Noise?
I am just curious, sometimes while at low RPM's I can feel my transmission kick back into work so to speak when I resume throttle at low rpm's it does not do this if I am revving high just luggin around...it feels different to me than any other bike or quad I have ridden before but I have always ridden dirtbikes this being my first streetbike. Is there any cause for concern in this? I can also feel or hear it if I am in first and rollign really slow and work the clutch back and forth in and out of the friction zone. Can anyone shed light on this it has me worried a bit. Also worst case scenario how much does it cost to rebuild the transmission in my f3? Can it be done without splitting the cases, or do you have to take the whole motor and all completely down to the bottom where the trans is?
Old May 30, 2006 | 04:01 AM
rangerbrown's Avatar
Default RE: Transmission Noise?
tran rebould would require it to be taken apart. but this sounds like a bad chain.
how tite is it, remeber siting on it check it. should be no more than a 1/2in from down to up or vise versa. if there is a lot of slack then ajust it. if it cant then you need a new chain
Old May 30, 2006 | 07:47 PM
I just installed a brand new set of sprockets and a new chain last week. (The old one was in BAD shape) and it is not that I originally thought this too, it is definately internal when the cluth allows the transmission to take over. but only at low rpms
Old May 30, 2006 | 10:39 PM
it could be any thing, i would take to a shop and have them go over it. sorry i cant be of more help
Joef2
F2 Tech
Jun 27, 2012 02:51 AM
cnguyen
Aug 8, 2010 10:50 PM
durty116
Jun 11, 2009 10:14 PM
tdawgcycles
Apr 29, 2007 06:46 AM
hondadriver4life
Mar 22, 2007 05:46 PM
