took carbs off, random hose...
#21
you put it back in?
If not do that and follow my last post. It can drive you crazy till it is set right. also another thing you can do, if weather is warm enough. Is to put the screw in but leave kinda loose and leave choke off, crank and twist throttle and try to start it, if it starts then warm bike up by working throttle yourself. then set the idle.
#23
#24
Spark plugs doesn't bother me, but having to replace big ticket Item engine parts is what would suck because I would have to buy the part too.
#25
#26
Well I took the plugs out today and noticed some oil in there. And did some starter spray in the carbs and still nothing. Still have to take the carbs off again to get idle screw back on.
** It ran one month before I took off the carbs. It wasn't starting and they were really dirty. ONly part I didn't clean is the part that needs D-wrench thingy
