timing question
I was wondering if anyone new what marking on the crankshaft has to be lined up with the mark on the casing of the bike? Is it the T mark or is it the 2 dots or 3 dots im not to sure and im having an issue with cylinder number 1 not firing but im getting a spark to it if someone can help me figure this out i would be greatly appreciated...
hi mate,i believe it to be the line just befoe the "T" mark for TDC to start with,then rotate 180 degrees to get the line on its its own vertical,then you rotate again (clockwise of course) to line up with the T mark itself,then another 180 degrees to use the vertical line again.
hope this helps,
safe riding.
Ant
hope this helps,
safe riding.
Ant
