Throttle Sticks
Old Dec 10, 2008 | 08:28 PM
MrBomb's Avatar
Default Throttle Sticks
First started to notice this problem this season. When I twist the throttle and let go of the handle completely it won't snap back, it starts moving very slowly then when it gets to a point it goes back a little quicker. There is no problem while riding, I can't even notice it when my hand is on the throttle, as I just move it back myself. I was just thinking if I ever lost control at some speed, the bike would keep powering itself down the road.
So do i just have some sticking throttle cables? Or what else might be your ideas?
Old Dec 10, 2008 | 08:32 PM
MrBomb's Avatar
Default RE: Throttle Sticks
Not sure why I didn't search before I made this, but I think I just found some possible solutions, sorry about that
Old Dec 10, 2008 | 08:33 PM
redzintimidator's Avatar
either your throttle cables arent sliding smoothly...or your throttle return cable isnt tight enough...take off your tank,and maybe airbox i dont remember if the airbox is necessary to get to the adjustments...then just play around with those until it snaps back smoothly..if it never gets smooth then your cables are probably rusted or something...let me know if you need cables cause i have an extra set.
Old Dec 10, 2008 | 08:39 PM
grizzly's Avatar
i have an f3 and f2 the both have this problem. i think that they're just old.
Old Dec 10, 2008 | 08:42 PM
grizzly read that /\..lol
I used to have this problem, but not anymore. If you take the cables off the carbs, and they move relatively freely, they are good...if it takes a lot of effort to move them then they are bad....doesnt matter if the bike is old or not this can be fixed
Old Dec 10, 2008 | 11:13 PM
f3BikeR's Avatar
I had this similar problem just a few weeks backs.
When I had the tank and airbox off, I did make some adjustment to the throttle cables and I sprayed them with wd-40/liquid wrench in that area..
I then sprayed some under the white throttle tube after taking apart the plastic assembly containing the starter button and engine stop (a few screws). Just sprayed some underneath the tube while sliding the grip to the right just 1/8' or so. This absolutely CURED the slow closing of the throttle!
Old Dec 11, 2008 | 11:25 PM
xander071584's Avatar
i had that problem once on my first bike a 99 ninja 250 and i used wd40 also, it worked pretty good.
Old Dec 13, 2008 | 08:51 AM
MrBomb's Avatar
just tried a little wd40 and looks like it did the trick, thanks guys
Old Dec 13, 2008 | 12:32 PM
Hurricane rider's Avatar
you also should take some time and lube the throttle cables proper so they dont develop a sticking condition. its just for the peace of mind overall really.
magnumRT
F2 Tech
Aug 9, 2012 08:05 AM
filthydanger
Feb 24, 2011 01:04 AM
N8 Dawg
May 7, 2009 07:04 PM
skatalact
Mar 15, 2009 07:59 PM
mitchedwards81
Mar 13, 2007 03:38 PM
