Throttle return problems
Old Apr 2, 2012 | 06:15 PM
yteka99's Avatar
Registered Users
Default Throttle return problems
I just replaced the throttle cables on my buddies f3. With the whole assembly off the bar it'll snap back no problem perfectly. But on the bar it really takes a noticable amount of force to open or close it. I can see it's bent but so is the other side so I assume it's supposed to be like that. The bike was backed into and fell on it's throttle side. Is there a chance it got bent out of shape and that's what's causing it to not open/close properly?
Old Apr 2, 2012 | 07:30 PM
underground-mpyre's Avatar
Check both sides of the grips and see if that is causing the sticking. Fixed my friends R6 in 30 seconds when they were planning 3 hours to fix the sticking throttle.
Old Apr 2, 2012 | 07:38 PM
yteka99's Avatar
Registered Users
I'm not quite sure what you mean by check both sides of the grips? Like pull the left bar and compare? I forgot to add, the bike was hit by a car and tipped in a parking spot on the throttle side.
Old Apr 2, 2012 | 07:46 PM
coalminer frank's Avatar
Make sure the grip is not squeezed up against the starter/kill switch housing. Also did you follow the original cable route?
Old Apr 2, 2012 | 07:53 PM
dyracuse's Avatar
I would look at the throttle tube, a lot of times they'll break in a fall, mine on the dirtbike would act up when it was cracked.
Old Apr 2, 2012 | 10:41 PM
marc0011's Avatar
Assuming the cables are adjust correctly, make sure the bar and the tube are clear or nasty old grease. When you're done cleaning, use some white grease.
Just a note from personal experience. I've used the Bel-Ray water proof grease on the bar and it was too heavy. When I released the throttle, it would slowly return. Once I cleaned it and used white grease, the throttle would snap.
Old Apr 3, 2012 | 01:37 AM
CJardine's Avatar
Track junkie & modaholic
Are the cables routed correctly? I know on my bike even if the two throttle cable are resting on each other, my throttle tube will slowly reset when released. so I would start there before ripping into anything
Old Apr 3, 2012 | 10:13 AM
yteka99's Avatar
Registered Users
The only way they aren't correct would be if maybe they're twisted. I listerally had all 4 cables (new and old) in the same spot at once to make sure of that. I'm gonna have to try to clean it then, I don't want to tell my buddy to order new parts if he doesn't have to. I just don't think it's dirty because it would have done that before.
Old Apr 4, 2012 | 04:27 PM
marc0011's Avatar
If they aren't adjusted correctly, they'll bind too.
bohdan
Sep 27, 2012 03:45 AM
kellie
May 29, 2011 06:04 PM
tyfishfinder
F2 Tech
Feb 16, 2011 04:16 PM
blakesgst
Oct 2, 2009 05:48 PM
driyac
May 16, 2009 05:40 PM
