things to look for when buying
Old Oct 19, 2015 | 11:37 AM
two-stroke-brit's Avatar
Default things to look for when buying
hi all, been lurking for a while,
a neighbor has a F3 for sale, but has not run in years .
he is trying to get it running before selling,
allegdly they are known for the fuel pump,petcock and clogged carb issues from sitting for too long .
what other F3 specific probs are there to look for .
thanks mark.
Old Oct 19, 2015 | 11:57 AM
Mattson's Avatar
That`s pretty much it. IF he gets it running listen for a rattle when idling which should go away when given revs and then return at idle, that would be the cam chain tensioner. A good leverage to talk down the price, that is if he doesn`t know it`s a 20min fix to replace the tensioner. One part that sometimes fail is the regulator/rectifier, pop off the right tail fairing and look for either a black box or a metal casing with cooling fins, one or the other it should have three yellow wires and a few others, look for heat damage on the connector/wires, that`s a telltale sign of it going/gone.
The bike itself is pretty much a tank, it can take a helluva beating and still keep going. Other things would be something like checking for excessive slack in the rear sprocket carrier, the rubber inside wears out and can get brittle over time, other than that just normal wear like wheel bearings and such.
Old Oct 19, 2015 | 12:05 PM
thanks , good info .
the fork seals are leaking to.
i am hopping he gives up and lets me have it cheap.
cheers mark
Old Oct 20, 2015 | 07:17 AM
Mattson's Avatar
Any time. If you end up buying it put up a build thread here, any problems at all there's more than likely someone with info here.
Old Oct 20, 2015 | 10:45 PM
Conrice's Avatar
Doesn't sound like an "issue" to me - sounds like a problem ANY and EVERY carb'd bike has that sits. Its where the term TLC comes from.
The fact that he's trying to get it running is telling. It tells me he thinks or knows its something simple.
If you're mechanically inclined, go take a look. The only thing Hondas are known for negatively, is the CCT, which Mattson stated already.
pyrosive
Oct 21, 2012 06:32 PM
bigcore08
Jul 23, 2007 07:58 AM
shmiddy
Jun 1, 2007 06:47 PM
SenSpeed
Sep 28, 2006 12:48 PM
motokid
Apr 20, 2006 09:40 PM
