Temp. Guage
RE: Temp. Guage
thermo sensor gone bad. its beween the frame and carbs. to remove drop engine, and then unscrew then install new. part no longer able to be bought new, check ebay or local junk yards. i had to replace mine, but broke it off in the block. so i had to drill and tap the thermostat houseing to hold the use one i got. it now works
RE: Temp. Guage
you could get a after market temp plug (advance ect...) and just clamp it on to the termostat houseing (under the right fairing) and then run the gauge up to were you can see it. it wont work great but it will at least give you a idea as to whats going on. the fan should come on at or around 140-180.
