Swapping to digital console
Heya, i've been thinking since i am in the process of fixing up my bike and everything is off of it i might as well throw in a digital console, however i'm not sure where to go, or what would fit it, if i used a F4 console would it fit in place of the stock F3 one? And are there aftermarket digital consoles i could get? Any advice would be appreciated thank you.
F4i gauges is the way to go if you are goin digital, you just need a 98-99 cbr 900rr thermo unit, and some time and patience, some male/female connectors, a little bit of wire for a constant power for the clock, and a cluster mount, I made mine out of 1/8 inch plexiglass stacked so there wasnt much flex, i bought 2 12'' by 12''squares was able to make 4 out of them, i would have had extra but slipped on a few of them.
Lol you slipped on a few of them? the cluster mount wont be a problem i can actually weld the F3 console mount to fit the F4i one should not be a problem, did not know about that thermo unit though ! thanks the rest should pretty pretty simple. Where did you run the wire to ?
