stock guage cluster LIghts?
My lights went out for my SPeedometer/RPM/TEmp guage. Everything else works Blinkers,oil,neutral,kickstand. The rpm still read correctly when reved and the speedometer is functional. All the bulbs are good, i cheked fuses under panel and there all good. I don't know what else to check. CAN someone help me out please, i do a lot of night riding.
I read the whole thing and it might just be the bulbs.
On my old Yamaha SecaII I had the lights go out completely. THen one day I took a turn and they came on for a bit. Then they were out. Finally I got fed up and replaced the bulbs and they all worked.
If you do get the new bulbs you have to go directly through Honda.
If the bulbs don't fix it then possibly bad wiring.
Yeah, i checked the bulbs again by taking a supposed bad one and putting it in where there was a functional bulb and it worked but won't work in the spot it orginated from. I gave up on the cheap POS, i just got a f4i guage from ebay and i am going to attempt tomake a smokedplexiglass background and bracket to mount. DOes anyone know if there is somthing cool to buy to mount the f4i guages?
