steering damper stroke/length?
Old Jan 16, 2013 | 03:48 AM
jackojeff's Avatar
Default steering damper stroke/length?
anybody know what length the steering damper needs to be the sprint pro race im looking at has options of 50mm, 70mm and 120mm.
its for a race bike before you tell me i dont need one
thanks
Old Jan 25, 2013 | 04:22 AM
gpfan1's Avatar
For a street bike, you will probably use the 120 mm stroke. If you use a shorter stroke you will need to add some screws to the steering stops to prevent using the damper as a steering stop. It can damage the damper as well as pull it off in an extreme situation. I have an Mtoby damper and will measure the stroke and post it back here.
Old Jan 25, 2013 | 07:27 AM
kjohnson's Avatar
kjohnson88@bellsouth.net
Hit me up on my email,I'll measure one of mine for you.
Old Jan 28, 2013 | 12:26 AM
gpfan1's Avatar
I measured my Mtoby and it is a 120 mm stroke. It mounts along the side of the frame above the side access panel. It allow the full sweep of the steering stops.
Old Jan 28, 2013 | 03:30 AM
jackojeff's Avatar
i ended up getting a 75mm one as it is an arrow damper for £52 worth £300 new happy me. its a race bike so im not going to be hitting the steering stops alot and could you get a pic of how its mounted please? i was looking at mounting it at the side but looked easier to mount underneath were the ignition barrel used to sit.
Old Jan 28, 2013 | 10:36 PM
gpfan1's Avatar
Default Damper install
This is how the 120 mm damper mounts on my f2
Attached Thumbnails steering damper stroke/length?-mtoby-f2-damper-install.jpg
Lapointeslair
Feb 4, 2013 11:32 AM
gregtutch
Sep 13, 2011 04:52 PM
Caveman 954
Jul 7, 2010 04:36 PM
Handan
Nov 1, 2006 12:57 PM
FordFrenzy97
May 3, 2006 05:49 PM
