Starting oddity
Old Mar 13, 2013 | 03:09 PM
testflyer's Avatar
Default Starting oddity
More than once while trying to start a cold engine: it cranks, but won't light (because its cold). Hit the starter button again and nothing...dead. Like its Got no ignition. Turn the key off and back on, it cranks and then engine fires up. when it happens, turning the ignition switch off and then backs on seems to reenergize the starter. New battery. I'm starting with motorcycle in neutral, clutch out. Side stand down.
Any thoughts? Happened after winter hibernation....unheated garage.
Old Mar 16, 2013 | 09:02 PM
FOGeologist's Avatar
Senior Member and ROTM March 2014
My guess is corrosion in the ignition switch. If you go to the online manual, in chapter 18 there's a procedure for a replacement.
BlackDogIron
Sep 14, 2017 05:47 PM
Mattson
F2 Tech
Oct 6, 2014 03:13 PM
marc0011
Oct 17, 2008 04:29 AM
ckxtreme
Oct 7, 2008 10:50 PM
takirb
Feb 18, 2006 06:50 PM
