Start problem again.. fuel pump?
Old Apr 17, 2009 | 06:38 PM
marstenb's Avatar
Post Start problem again.. fuel pump?
I recently had a start problem where my bike seemed as though it was flooded, after I cleaned the carbs, jets and everything, it started like a champ and ran fine. Then a day later I drove it about an 1/8th mile and it quit. Now it wont start, it will just crank over but doesn't even pop or anything like it wants to start. It has new gas in it as well. I did take the hose off the fuel pump and tried cranking it over to see if any gas would shoot out but none did... so could the fuel pump be bad?
Old Apr 17, 2009 | 06:54 PM
Yes, it definitely could be the fuel pump. As a test, you could bypass the pump and go directly to the carbs from the tank. If it runs, then get a new pump, they're about $110 new. They go bad fairly regularly. Don't buy used, because its just as old as yours. Gravity feed is fine for idle, but not for riding around.
Old Apr 17, 2009 | 08:29 PM
marstenb's Avatar
Default same problem
Tried to bypass fuel pump, its still doing the same thing. I can hear a hiss sound every once in awhile... now what?
Old Apr 17, 2009 | 09:41 PM
Is fuel getting to the carburetors ? Loosen the drain screw on the bottoms of the bowls and see if fuel comes out. Are the plugs wet ? Are you getting a spark ?
Old Apr 17, 2009 | 10:58 PM
marstenb's Avatar
Default Tried everything
I cleaned the carb bowls, cleaned the jets, put new spark plugs in. It still seems like its not getting spark on top of bypassing fuel pump. Suggestions?
Old Apr 18, 2009 | 06:46 AM
Adamavage's Avatar
Maybe try taking off the tank and air filter housing and shooting some starting fluid into the carbs. Also have you adjusted the idle control? I know mine was really tricky....by the way I'm also having a starting problem and trying to figure it out I'll let you know how it goes.good luck!
MrFox
Oct 7, 2012 09:56 PM
samba2
May 23, 2012 11:12 AM
Red Zeder
Jul 31, 2011 03:27 AM
xxenycejattxx
Oct 21, 2008 01:35 AM
philbee
Oct 12, 2008 12:11 PM
