sprocket
OK so My 96f3 is nice and fast but the guy who owned it before me went -2 in the rear, He said he didnt know if the front was stock or not so Iam going to change them both because the bike has little power till 6000rpm I would like more low end, Right now the front end is lowered so the wheel will not come up no matter what. I have tried to power it up at all different kinds of rpm in first and Tried to clutch it up and there is not luck, I dont want to be trieing to keep in down in third but I would like to get it up and have some fun. what would you guys do with the sprockets ?
i know that my 97 was sitting at 15 on the front and 41 on the back and I could power up in first second and third, but i also had an ignition advancer, and a stage 3 jet kit. I would replace the clutch before you replace the sprocket, unless the chain s already gone... You would be surprised how much difference a worn out clutch will make on the f3.
I'm going to go with -1 tooth on the front sprocketfor a 14 front and 43 rear combo.With that setup, I get to keep the stock 525 chain and get a steeper gear ratio than+2 on the rear. I will definately be getting a speedo-healer though! However, I can clutch it up with the stock set-up now.
BurntDragon
BurntDragon
ORIGINAL: jdavis
Thats what I was thinking of doing also.I dont know if I can clutch it up now. but I really dont like to try it out.
bowtieboy42
F2 Tech
07-10-2012 03:53 PM
kreush33
05-21-2006 12:28 AM
