Speedo help
Old Apr 1, 2012 | 10:09 AM
Burnupking's Avatar
Default Speedo help
Hi can someone help me I just been out on my bike and it just started playing up the speedo stopped working and but runs fine in first and seconded gear after that it misfiring in 3 4 5 and 6th gear can some 1 help me please
Old Apr 1, 2012 | 10:19 AM
Welcome to the forum. I'm assuming that since you're posting in this section that you have an F3 of some year. The speedometer gets it signaling from the speed sensor that's located above the output shaft/front sprocket. The Pink/Green wire goes to the Speedometer. I'd check for a loose connection between these 2 places.
Old Apr 1, 2012 | 10:25 AM
Burnupking's Avatar
Thanks will have a look now yer it's a 98 . This site look to be Best I've found on the net for cbr
Old Apr 1, 2012 | 03:45 PM
derekvercher's Avatar
as for the misfires. could be carbs.
Old Apr 1, 2012 | 04:36 PM
Burnupking's Avatar
Stop no good I unplugged it and replugged it and still no change think a full strip down in Order unless and over idears ?
Old Apr 2, 2012 | 08:34 AM
id check all your electrical connection first. ive had some get corroded and cause problems. check your fground wire too. i had a high speed stutter once due to a looses ground wire.
niner29
Apr 13, 2009 07:39 PM
country1430
Aug 18, 2008 12:42 AM
kave115
Jun 13, 2007 04:20 PM
paul0044
Jul 8, 2006 04:12 PM
