Some people shouldnt own motorcycles....
Was cleaning my carbs (yet agaaainnnn ) and i replaced all my fuel lines and saw some electrical tape on the wires going to the fuel pump. so i took the black cap off the bottom, and found this:
so i soldered and fixed that. i was mad at first... but them i remembered that the previous owner(s) did this:
who knows what some people got goin on in their minds. ANYWAYS. yeah i was cleaning the carbs cause i got BAD GASOLINE from the CITGO gas station by my house. didnt know it. i worked out of town for a while and the bike sat there and it jelled up in the float bowls. nasty nasty stuff. i cleaned them out all good and put everything back together and put the gas tank up on a shelf and put a very small amount of fuel in there and ran a fuel line to the fuel pump and got the bike warmed up then when it was choking out of fuel i dumped sea foam into the tank, let it suck that through and let it sit like the can said. then came back and poured a gallon of gas in the tank and revved the **** out of her and cleaned her out. havent ever had a better throttle response than now.
side note: i got vapor lock on the gas tank while i was letting it run after it was warmed up. i never got vapor lock on the tank while it was bolted to the bike. any ideas? it was choking out and i was like ok must be empty so i took the lid off and it was a force holding it down and i took it off and it hissed in, and the bike started running like normal.
I feel your pain. After my wreck I started going through all my wiring and re-looming it to make it all pretty and clean- I found 4 places where the PO had cut some wires, twisted them together, put some super glue over them and wrapped them in so cheap-o electrical tape. Being that electrical work is my career I about cried...LOL
should i stick something small up in there to try and clean them out? please, if you tell me i have to take my carbs off again to clean them... im going to go run out in traffic right now.
