Idle speed cable problem ?!?! please help
Old Oct 26, 2010 | 02:36 AM
fordy861's Avatar
Default Idle speed cable problem ?!?! please help
I have a 1995 honda cbr600 F3 (n reg)
The idle speed cable has come away from the carbs or were ever it goes, i have removed te seat, fuel tank, air box, and i cannot see where it is ment to go... Getting very frustrating now as i dont want to take to a garage for something so simple!
Pleaser help me
Thanks
Old Oct 26, 2010 | 04:39 AM
spicymeowmix's Avatar
Official Welcome Crew Spicy Cat
Pleaser help me
Thanks
it mounts under the carbs... id say you're gonna have to take the boots off to remount it and fix the problem... but if you are crafty enough, it might be possible to get it back on there with some small hands (aixbox / ram air tubes removed)
Old Oct 26, 2010 | 10:46 AM
espelade's Avatar
I used a metal coat hanger to put mine back in. Twisted the end into a loop fed the cable through it and was able to use that to line it back up to screw in. I then backed the hanger off enough that I could unbend it with some needle nose pliers.
It screws into a plate between the #2 and #3 carbs.
Check out this thread- it has a decent photo of where it goes... (granted its with the carbs off, but you get the idea)
https://cbrforum.com/forum/f2-tech-93/carburetor-cleaning-tuning-101-a-96888/
2H company
Oct 31, 2011 11:06 PM
stanwither
Jun 18, 2011 07:09 PM
shoortbuss
Feb 15, 2008 11:57 AM
pointman
Sep 11, 2006 01:53 PM
gyrowiz
Feb 14, 2006 07:07 PM
