Sludge in my radiator
Old Dec 11, 2018 | 08:22 PM
Patrick7's Avatar
Default Sludge in my radiator
My F3 has this brown sludge in the radiator, I’m figuring oil. Checked oil, clear as a bell but radiator is sludge. Drained it twice but still doing it, it also overheats and spits this sludgy liquid out of top hose on radiator, the tiny one going in to to cap part. Head gasket??? Anyone?
Old Dec 11, 2018 | 10:27 PM
74demon's Avatar
Oil cooler seals are common, if yours is equipped with one. Couple of orings....
Old Dec 11, 2018 | 10:30 PM
If your oil is clean and you aren't losing coolant, it's probably just a bunch of crud built up over the years. Just keep flushing it with water until it comes clean.
I seem to remember a thread from a year or so ago where someone had the same issue. Take a look to see if you can find that thread.
Old Dec 19, 2018 | 08:54 PM
Phil314's Avatar
If your oil is clean and your getting oil in the cooling system (overflow tank or radiator), it's not a head gasket.
It is very common on F2/F3's when the oil cooler seals start to leak. This lets oil into the coolant.
They are easy and cheap to replace with the engine in the bike.
I've seen way to many people pull engine to do head gaskets when that isn't the problem.
bellbottomsdj
Jun 13, 2014 07:31 AM
ampfp
Jul 22, 2011 02:59 PM
gtogottogo
May 19, 2009 03:30 AM
dmashev
Feb 11, 2008 07:28 PM
HurricaneForce
Dec 25, 2006 02:31 PM
