Change the place of oil radiator - CBR1000F,1992
Old Feb 10, 2008 | 12:12 PM
dmashev's Avatar
Default Change the place of oil radiator - CBR1000F,1992
Is there a problems with cooling of the enginе If I change the place of the oil radiator.
Old Feb 10, 2008 | 08:44 PM
Shadow's Avatar
Default RE: Change the place of oil radiator - CBR1000F,1992
If you make the pipes longer, you MAY have oil pressure problems - I moved one on another bike, and did......otherwise, it won't matter unless you restrict airflow to the water radiator........but why move it anyway ?
Old Feb 11, 2008 | 06:35 AM
dmashev's Avatar
Because I want to make a streetfighter.
This is where I want to put oil radiator.
Old Feb 11, 2008 | 07:14 AM
Shadow's Avatar
Definitely NOT a good idea, unless you fit a good fine gauge metal stone guard, which will limit the effectiveness of the cooler. Oil coolers are quite fragile, and a stone getting kicked up could well punch a hole in it down there, resulting in
1 Oil all over the back tyre, resultant loss of grip, and possibly loss of life..yours or someone else's
2 Dumping the oil from these high-performance engines, and you'll lose pump pressure, and if you don't see the oil light (it's generally too late by then anyway) a blown engine
3 Pipes will need to be lengthened....loss of pressure..?
You could even hit a speed bump and smash the thing ..
I wouldn't even think of moving it down there.....[sm=badidea.gif]
Old Feb 11, 2008 | 08:45 AM
malbojah's Avatar
KILL IT! KILL IT WITH FIRE!!!
Old Feb 11, 2008 | 09:49 AM
TimBucTwo's Avatar
I agree with Shadow1. Also, there is less air flow down below behind the tire.
Old Feb 11, 2008 | 07:28 PM
meatpopsicle's Avatar
I went to an aftermarket automotive oil cooler and attached it directly in front of the radiator. Moving the stock cooler with the stock lines is going to be difficult. You'll likely need custom made lines.
kenshin81
Sep 25, 2013 07:47 AM
big24fanz
Oct 3, 2011 05:22 PM
Cytotek
Jun 16, 2010 11:10 PM
griff4444
Jul 30, 2008 07:27 AM
schooners
May 26, 2007 10:25 PM
