screwed up my right fork on the f3
Old Jun 1, 2009 | 07:19 PM
catalyst.'s Avatar
Default screwed up my right fork on the f3
Well one of my axle pinch bolts broke off inside the fork so i was drilling it out for a new bolt and low and behold i put so much pressure on the fork that it broke the damn thing, now with i hold the upper shiny part of the shock and twist the lower section there is play in it.
What do i do now? what could be broken inside the fork and could i fix it?
Old Jun 1, 2009 | 08:47 PM
Phil314's Avatar
I seriously doubt that you broke the fork just by trying to drill out a pinch bolt.
If you mean the lower part of the fork will spins around separate from the shiney part, that's normal. Or do you mean something else.
Old Jun 2, 2009 | 09:25 PM
Chuk97's Avatar
did you just smash the seal?
Old Jun 4, 2009 | 01:46 PM
marc0011's Avatar
I think he means that the lower fork leg spins around on the fork tube which is normal just like what phil314 said. You're all good, just be careful when drilling on the fork leg. It is a really soft aluminum and you could damage it easily. Are you just going to drill the whole thing out and then retap the threads?
Old Jun 5, 2009 | 11:19 AM
johnnyx's Avatar
Yeah, +1 on "you didn't break the fork."
Old Jun 8, 2009 | 09:29 PM
SUMORYDR's Avatar
I doubt you broke the fork too but if it's worth $100 I can send you a set that we've got around here....
Send me a PM if you are intersted at all.
Old Jun 9, 2009 | 12:28 AM
catalyst.'s Avatar
Well, i really hope you are all correct, i just examined it again and it actually doesnt seem to be broken.. but anyway i am still drilling out that damn bolt which seems to be made from titanium.
where are the seals located? how could i smash them.. i really put alot of pressure against the fork.. to much i was really pissed and at the end of my rope.
nobody
Apr 18, 2010 08:27 PM
maineiack
Feb 3, 2010 09:28 PM
Pistol_Pete
May 22, 2009 06:16 PM
JDubF4i520
Jul 21, 2007 02:45 PM
alex71783
Jul 11, 2007 03:10 PM
