rough idle and rpm problem?
It kind of sounds like valves, but I am sure that it must have been there before you did your service work.
With the way your engine sounds, you really need to check and adjust as needed.
Be sure you feel confident in doing this or get help from someone you trust.
I bought an ATV with no compression and found out that someone over adjusted the intake valves, causing them not to seat. I was lucky that the valve never burned up!
GOOD LUCK
PS > Does anyone ever run LUCUS in their engines?
GOOD LUCK
