Replaced brake pads now caliper wiggles Help!
I replaced my rear brake pads and put everything back on correctly including the rubber gromet thing on the upper bolt, now the caliper wiggles a little and under hard braking will make a clunk noise. Both bolts are cranked down as hard as they can go
I took it apart and put it back together about 5 times and had no luck. Any tips?
I went over the manual and the only part I didnt follow was that I took both bolts off rather than swinging it upward.
I just replaced all my pads, i managed to break one of the rear caliper bolts in half
Did you take caliper completely off and make sure the pads where seated in the little metal tabs right? Idk why itd be wiggling...theres only that 1 top bolt holding my caliper on and it dont wiggle really.
Meant the ones in the caliper...they bend easy.
Well I rode around last night with this loose brake and managed to get a speeding ticket while doing it. I read on some forum that this is normal for floating calipers, does the f3 have a floating rear caliper?
Michaud85
Jun 25, 2012 11:41 AM
