removing and replacing brake pedal
Old 03-31-2009, 01:02 PM
89cane's Avatar
Default removing and replacing brake pedal
hey i laid it down awhile ago and the brake pedal bent i was wondering how to remove and replace it. i have the rear set off and i took off the e clip on the back but i still cant get it off.
Old 03-31-2009, 06:59 PM
SIRR1's Avatar
Sounds like you bent the pedals shaft if you removed the clip and washer and it will not pull off the mount.
It could have some rust built up on the shafts ends also, the bike is over 10 years old.
Try spraying some WD40 onto the pedal shaft, let it sit over night and see if that helps.
Try using a small gear puller one that pushes on the shaft while pulling on the brake pedal.
You can always beat the pedal back into shape since it's steel.
I would NOT use heat when trying to remove the pedal.
The rear set is aluminum and and if you get the pedal shaft to hot it will start to melt the aluminum and distort the peice, push the shaft throught the rear set or just ruin the rear set.
You can find these items on ebay for 20 bucks plus shipping.
SIRR1
ObsidianOne
03-26-2014 04:31 AM
Avi
11-14-2011 03:03 PM
zellster
09-26-2011 09:39 PM
Logical_Apocalypse
01-28-2011 07:57 PM
F4LIFE
06-14-2010 09:11 PM
Quick Reply: removing and replacing brake pedal
