Rear Preload
Old Sep 1, 2006 | 11:52 AM
tvoburner's Avatar
Default Rear Preload
Hi all,
I've just bought a 1995 cbr600f without an owners manual and I want to check/adjust the rear
preload setting but I'm not sure how to go about it. I have the c spanner that was in the tool kit and I
have a ring with numbers on it (1 to 7) at the base of the shock absorber which I have tried to turn but it
won't move, am I missing something ? as I have strained both ways but it's stuck, also is there a mark
somewhere that the numbers are supposed to line up with ?.
Any help gratefully received
Dave.
Old Sep 1, 2006 | 12:24 PM
mikequinn's Avatar
Default RE: Rear Preload
Give it a good yank it'll move... the stock setting is 3 I think for a normal joe, but I run mine on 5... don't forget everyone is different so experiment and see whats comfortable for you, I had real trouble getting mine round long bends until I saw the previous owner had it on #1 so there was no weight on the front. don't forget the rebound and compression damping too.
Old Sep 1, 2006 | 12:50 PM
tvoburner's Avatar
The number 1 is at the top of the ring, is this how you tell what the setting is or is
there a mark somewhere else that the numbers should align with?.
Many thanks
Dave.
Old Sep 1, 2006 | 10:43 PM
mikequinn's Avatar
number 1 is the lowest setting or the weakest spring pre load... as you go up in numbers your putting more load on the spring..
Old Sep 2, 2006 | 12:00 PM
tvoburner's Avatar
Thanks guys for the help, I've managed to get it to move with a bit more leverage
and have set it on 4 so I'll see how that goes.
Regards
Dave.
sportacer
Nov 22, 2013 10:08 AM
flyingfree9
Jan 20, 2010 02:09 PM
Mo777
Apr 9, 2009 06:59 PM
Nauree
Jul 22, 2007 06:16 PM
gtjimm
Jul 26, 2006 11:51 AM
