Radiator fan stopped working..
i had a similar problem. two possibilities that aren't hard to check. there is a switch in the lower left side of the radiator that activates the fan. if it's not working then obviously that will do it. you can connect a 12v lead to the fan and see if it fires up, then it could be the switch. as simple as it sounds check the coolant level. once my was too low for the switch to read the temp. i filled it and was fine. keep us posted.
