question about rear sprockets?
Old 04-02-2006, 03:27 AM
golion2k's Avatar
Default question about rear sprockets?
what exactly does changing the rear sprocket do? I've seen sites selling 520, 530 rear sprockets? is the higher the number the better the sprocket ? thanks
Old 04-02-2006, 03:41 AM
Default RE: question about rear sprockets?
im not really sure but i think if you size the right sprocket you can make it have a faster accelleration.. bigger spockets i believe are for stunting and stuff.. im not 100% sure
Old 04-02-2006, 03:45 AM
the number is the chain size.. 520 is smaller than a 525, which is smaller than a 530.. 520 conversions remove some rotating weight compared to the stock 525, but at the expense of chain life. The 525 would be stronger than the 520 in tensile strength, but its not really an issue..
I did a 520 conversion on mine, stock 43 tooth in rear, and -1 tooth in the front..
decreasing the front number of teeth, or increasing the rear number of teeth, give the bike better acceleration, but the top speed is lower.
In general, taking one tooth off the front, is the same as adding 3.5 to the rear.. so if you went -2 in the front it'd be equal to +7 in the rear.
At one point I had -1 and +5, and the acceleration was great, could power wheelie 1st and 2nd, and could clutch 3rd up, but I ride the highways alot and didnt like the fact that at 70mph, i was turning around 9,000rpms, so i went to a stock rear (43T) and am very happy now.
Old 04-02-2006, 04:44 AM
Is dropping one tooth in the front always the same as adding 3.5 in the back? Does it change per what bike you are doing the change to, or is that a pretty universal ratio? I am debating dropping 1 or 2 teeth in the front. My buddy is telling me drop 2 but i am just thinking of dropping 1, mabey w/ adding a bit in the rear...I dunno yet what I am going to do. I dropped one tooth on the front of my last bike it was a tuna 600 but it didnt really seem to make that much of a difference. anyways just thought i would float that question. thanks for any response.
Thanks,
-Loomis
Old 04-02-2006, 07:08 PM
You should notice the difference, unless it's already been dropped one tooth.. It's pretty universal about the -1 = +3.5 to all bikes, it's not always exactly 3.5, but you could prolly round to it.
It's generally recommended to not drop more than 1 or 2 on the front sprocket, due to increased load on the output shaft bearings, and the chain has to make too tight of a turn to make it around that smaller sprocket.. That being said, I usually only run a -1 front and if I want more, I add it to the rear sprocket.. rear sprockets aren't that expensive, but I think i've found my combo with a -1 and 43tooth on my '98. Great on the highway, but a noticible increase in acceleration with the -1 only..
Old 04-02-2006, 07:39 PM
NINE2NINE's Avatar
Retired Mod
ORIGINAL: Loomis
Thanks,
-Loomis
definately start with a -1 and see how you like it. then go from there. and to figure out the ratio of changes, divide your # of rear teeth by the # of front teeth. my bike stock was 16 front and 43 rear. so 43/16=2.6875. so dropping one tooth on the front is the same as adding a little over 2.5 on the rear. they give the same effect.
Old 04-03-2006, 12:00 AM
yea i was lookin in for new kits.. ill try what you got there too.. thanks
Old 04-03-2006, 01:15 AM
where can i buy front sprokets from whats a good web site
Adon47
07-02-2009 03:23 PM
cleansho93
04-17-2008 11:25 PM
A4wheelin
03-04-2008 08:19 PM
mitchapalooza
07-22-2007 06:50 PM
Phildo05RR
06-25-2006 09:37 PM
Quick Reply: question about rear sprockets?
