Rear Sprockets
Old May 22, 2006 | 07:10 PM
Phildo05RR's Avatar
Default Rear Sprockets
Hey i have a 05 CBR 600RR with a full exhaust and power commander and i can do first gear wheelies but i want a little more low end power can i just change my rear sprocket size or do i have to go down on the front then too? Plus i know changing your gearing will effect the speedo and odometer, can i just have a shop recaliberate it or do i have to buy a speedo healer? Thanks to all and i need some insight on the subject!
Old Jun 25, 2006 | 09:37 PM
gixxereater's Avatar
Default RE: Rear Sprockets
No, you dont need to go down in the front just because you went up in rear. You WILL however need a longer chain. Your stock one wont fit. Yes, it will throw off your speedo and no a shop cant fix it. You will need a speedohealer to fix that. You never want to go less than 15 teeth on the front sprocket as it puts too much bind on the chain. Just FYI.
Adon47
Jul 2, 2009 03:23 PM
cleansho93
Apr 17, 2008 11:25 PM
A4wheelin
Mar 4, 2008 08:19 PM
mitchapalooza
Jul 22, 2007 06:50 PM
golion2k
Apr 3, 2006 01:15 AM
