question
Old Mar 27, 2008 | 07:29 PM
shoemjay's Avatar
Default question
I cant stand to here that damn clutch noise.how do you get rid of it???? New Clutch plates/springs/???? anything else??? I have been doing some good wheelies now and using the clutch to get it up, now the clutch seems to be getting a little louder plus making some new funy noises like its falling apart.
can somebody please let me know if rebuilding it will eliminate the noise. OR a fix???
Old Mar 27, 2008 | 07:37 PM
Juliet's Avatar
Default RE: question
ORIGINAL: shoemjay
All I can say is the clutch is not designed to withstand constant wheelies ... it's for smoothly pulling off in first and changing gear ...really this is abusing the bike ... if you must do this then find out about a clutch upgrade ... OR ... accept worn out clutches as a fact of life ...
Jules
Old Mar 27, 2008 | 07:46 PM
shoemjay's Avatar
I hear ya and i appreciate the knowledge,I only do maybe two/three wheelies a day and the noise was there before i started doing wheelies but ive been living with it. so doing a clutch upgrade will fix the noise some or is there something else that needs to be fixxed. Thanks
Old Mar 27, 2008 | 07:53 PM
Juliet's Avatar
ORIGINAL: shoemjay
Only two or three a day ... lol ... wheelieng isn't something a road bike is designed to do ever, so even one wheelie rags the clutch a little, do it several times a day over a period of time and it's going to fail .. if it was already noisy before then you've just strained an already weak clutch ... when you treat a clutch like this apart from the wear factor you risk buckling the plates too which knocks it out of balance and makes it drag ...
I don't actually know of a specific upgrade but there maybe one out there ... clutches are normally long lived in regular and normal use but like anything mechanical the more you punish it the greater the wear and tear, hope you find what you need :-)
Jules
Old Mar 27, 2008 | 09:43 PM
Dakarai's Avatar
If you're pulling them alot, change your gearing. An increase in torque should help you from replacing your clutch once a year.
Old Mar 27, 2008 | 09:46 PM
Dakarai's Avatar
CBR600F3 95-98
Barnett Kevlar Clutch Kit[/i]
[/align] [/align]
Price
Kevlar Clutch Kit2012-402 $98.95 1 2 3 4 5 6 7 8 9 10 [/align]
http://www.morepoweracing.com/imuzo5...1-10712-10719/
Old Mar 27, 2008 | 09:55 PM
shoemjay's Avatar
SO thats all ill need is to upgrade my clutch, nothing to do with the clutch basket, 98$ isnt bad, do you have one installed or just know that its a good one? oh and my gearing is -1front+2 in rear
Old Mar 27, 2008 | 10:11 PM
Dakarai's Avatar
That's the set i have + flywheel. I didn't touch the basket.
Old Mar 28, 2008 | 10:43 AM
shoemjay's Avatar
what about the flywheel, you have a after market as well is it lightned or same size, did it come with the clutch kit or seperate? So you installed the clutch and fly wheel yourself? Was it tuff?Did it effect normal driving,or was it still smooth all around.
Cuz what im trying to acconmplish heere is to get rid of the clutch noise and ifthese parts did it for you, im ganna buy asap
odano1988
Sep 15, 2015 07:26 AM
bammerman
Jun 12, 2010 12:32 PM
600f4iHUNTERDON-NJ
Oct 8, 2009 10:30 AM
sempul
Sep 11, 2009 09:38 PM
viva_brasil
Jun 9, 2008 04:38 AM
