performance issues
Old Nov 6, 2008 | 05:18 PM
cajunlowrida's Avatar
Default performance issues
Hey guys, I'm looking for a little insight here. I have a 96 F3 and lately its been running pretty roughly. The symptoms are rough idle, a good bit of back firing under acceleration and a sudden strong smell of fuel when the bike is running. I've read that blocked tank vent hoses can cause this but mine are open and not tangled. I also changed the plugs but it appears none are fouled out. I also checked everything else and there are no fuel leaks and nothing else is apparently broken externally. I'm leaning towards an evap issue but it of course could be a valve issue. Any tips?
Old Nov 6, 2008 | 06:20 PM
ynks4evr's Avatar
Default RE: performance issues
has the bike sat for a period of time recently? if so your carbs could be gunked up, you could probably try some carb cleaner in the gas and see what happens
Old Nov 6, 2008 | 06:52 PM
No I ride the bike every day. I may try that anyway, or some lucas or something along those lines. It literally started this monday out of nowhere. A friend of mine suggested the choke was stuck open, but thats not the issue (although the idle does stay semi high after coming off the throttle to a stop).
Old Nov 6, 2008 | 07:30 PM
grizzly's Avatar
i bet its your battery. is it old? My truck had some running problems... bought a new battery and it ran fine! just by a new battery and try it out. if it doesnt work just return it. you might want to ask your local walmart or whatever on their return policy for batteries first
Old Nov 7, 2008 | 03:11 PM
ynks4evr's Avatar
^^^ that is also a good suggestion, i was having problems with my f3... it was starting but backfiring and running rough and i charged up the battery overnight and it was fine, might wanna start with that cause its a pretty cheap and easy solution (if you have a charger)
Iron_shaft
Mar 6, 2014 06:48 PM
craywm
Oct 5, 2012 01:48 PM
br4nd0n1234
Jul 21, 2011 08:06 PM
The Jim
Jan 29, 2010 09:11 AM
psychojoe22
Mar 16, 2009 11:43 AM
