Operating Temperature
Old 04-21-2012, 10:30 PM
tbow's Avatar
Post Operating Temperature
What temperatures do you guys usually run at during different ambient temperatures?
It's been about 65-80 degrees outside here the last few days, and while idling and going 0-25mph in traffic I'm at about 195-220deg (I have the F4i gauge temp reading). When I'm at 50mph+ it cools down to about 175.
I know the manual says the thermostat is fully open @203deg, according to my manual, but is running hotter than that a bad thing?
Thanks for any input.
Also my fan kicks on at 215 and then shuts off again after it cools down to 210. is that normal?
Old 04-21-2012, 10:32 PM
74demon's Avatar
Sounds about right to me.
Old 04-22-2012, 12:18 PM
ekelman's Avatar
Does not sound to me (not an expert) like it is running too hot. I do know that my machine F3 without digital temp display starts getting on the hot side if I am idling in traffic or moving very slowly. The cooling system on sport bikes are not typically designed with bumper to bumper in mind. I might add that I am running Engine Ice in the radiator and that does seem to keep things cooler. The manufacturer claims that it can lower temps as much as 50degrees F.
Old 09-03-2017, 08:57 PM
Kenneth Chadwick's Avatar
My 07 cbr 1k has been getting up to 230+ the last few days 100+ here in southern california and surprisingly humid. Recently added water wetter to the mix helped a little but still getting 130 at red lights. I wouldn't be too concerned unless you hit 140.
Old 09-04-2017, 08:13 PM
sjona2011's Avatar
that sounds normal. if it gets to/above 240, then you should start to worry.
lanceg
04-29-2009 06:49 PM
gursh d
05-05-2008 07:55 PM
95HondaCBRF3
06-02-2007 05:04 PM
Shocktroop
07-05-2006 11:43 AM
cbrven
05-18-2006 04:35 PM
Quick Reply: Operating Temperature
