Oil Pan Torque Specs
Old Jul 2, 2024 | 12:45 PM
kylehasyourfrenchtoast's Avatar
Default Oil Pan Torque Specs
Anyone know the Oil Pan torque specs? The Honda shop manual does not have any Oil Pan Torque specs listed. I also failed to replace the o-ring and check the pressure relief valve. However, will be replacing the input shaft bearing and everything will come off again.
Old Jul 4, 2024 | 11:30 PM
dannoxyz's Avatar
If nothing in manual, use generic specs listed here. Also be sure to clean those bolts and add dab of blue Loctite.
Old Jul 16, 2024 | 11:09 AM
Is there a torque spec for the petcock?
LowriderLo$89
Apr 15, 2013 08:43 AM
CrashTECH
F3 Wanted
Mar 18, 2010 06:51 AM
flypaper
Jun 13, 2006 05:57 AM
boxas2003
May 28, 2006 11:09 PM
visionjdm
Feb 14, 2006 05:17 AM
