oil on cluch side spark plug
Old May 8, 2005 | 05:23 PM
perryw's Avatar
Default oil on cluch side spark plug
hey guy's i have a 96 honda cbr i put it away last winter it ran fine i just pulled it out tryied to start it and it won't start. i got it going once it sounded like it was running on like two cylenders. and if i gave it any gas it die, then it stopped starting all together. i pulled the gas tank off replaced gas with new gas. tryied again nothing. i pulled the cluch side spark plug out and it was dripping with gas and oil. i replaced the spark plugs all of them, tried to start the bike nothing. pulled the cluch side spark plug out and it was dripping with gas and oil again!. what do i do now?
Old May 8, 2005 | 06:46 PM
sirlimpzalot's Avatar
Default RE: oil on cluch side spark plug
When you say clutch side are you talking about the "lever" side ( left side) or the side that the actual clutch cover is on ( right??)
If it is the LEFT (sitting on the bike left side, clutch lever side) it could be a carb problem since it is the lowest point if the bike was stored on the sidestand..like a stuck float assym...did you drain the float bowls before you tried to start it??
Old May 9, 2005 | 04:19 PM
perryw's Avatar
yes that would be the correct side (sitting on the bike the left side. is it easy to drain the carbs?
Old May 11, 2005 | 08:21 PM
perryw's Avatar
guys i pulled the carbs off turned them up side down opened the bowles and it all looks fine no grime or anything. what do i do next?
Old May 12, 2005 | 12:04 AM
so does it still do it?? Takin the carbs off may have been enough if you blew compressed air across the components to cure a stuck float valve
Old May 25, 2005 | 10:13 AM
perryw's Avatar
hey guys i think my feul pump is out it makes this thuk sound when i turn the bike over. does any one know what voltage you are to have on it cause i get 7.5 volts or so.
Hyena
Jan 14, 2013 11:17 AM
f4tal
Apr 10, 2008 06:21 PM
some guy #2
Jul 29, 2007 02:34 PM
alpha omega
Jul 15, 2007 04:15 PM
allnath3
Nov 5, 2006 12:31 PM
