Oil change question
RE: Oil change question
Yeah, that's the right hole! Ah! Yeah! Right there!!!
Sorry, yes, you pour the oil in there. As to checking it, you're gonna want to have the bike standing straight upright, or, you won't get the right reading. At least that's what "they" say. And, you never know if "they" are right
Tylor
Tylor
ORIGINAL: cbrjeeper
Tylor
Tylor
So the bike should be level? and the oil up to the middle line?
Yeah, "they" do say to keep the bike level. Just stick a block of wood or a nice sized book under the sidestand.
As for the "middle line", if I'm understanding you correctly, I think you are referring to the "upper level" line. If that is the case, then yes. I've attached a pic from the F3 shop manual. Also, they recommend that you check the oil about 3 minutes after shutting the engine off after letting it idle for about 2 - 3 minutes. With the dipstick just (tee hee) stick it in the hole. Do not screw it in. [sm=smiley9.gif] OK...this is starting to sound like a bad ****...."Hey! You're not the regular pizza guy!" (bonk chinka wonk wonk)
